Idleing problems?
Old Jan 19, 2004 | 04:56 PM
altec's Avatar
altec
Default Idleing problems?
I went to start my car 1994 integra ls the other morning and when i started it, it reved to about 2 rpms and then dropped to 1 then bounced from 1 to 2.5rpms and just keeps going like the energizer bunny......if i disconnect the air sensor on top of the throttle body it drops in rpms then when i plug it back in it stay about 1.5 rpms..making my check engine lights come on....(light is not on till i unplug the sensor) could it be a bad sensor or worse? I also checked to make sure my value cover gasket wasnt leaking oil into the plugs, thought that might have been the problem in the first place...................any help would be great
-a worried integra driver-
emails welcome........ xx_forces_xx@hotmail.com
Old Jan 19, 2004 | 05:34 PM
AP2's Avatar
AP2
Moderator Alumni
-Check if your PCV valve is disconnected
-Check the tension on your throttle cable
-Check all your vaccum lines
Old Jan 19, 2004 | 05:56 PM
altec's Avatar
altec
how would i know if the tension in the cable has changed? Could the throttle sensor be the problem?
Old Jan 19, 2004 | 07:15 PM
Born To Lose's Avatar
Born To Lose
It could be your fast idle valve. I broke mine while installing the intake. I went to the junkyard to get another one but i guess it's broken as well. Try changing that. I've heard of others having the same problem. Hope this helps!
