WTF? Why is it decelerating?WTF?
Old Jan 17, 2004 | 01:30 AM
92gsr's Avatar
92gsr
Default WTF? Why is it decelerating?WTF?
Hey guys I need your help. This is the 2nd time this has happened. Last time this happened was probably 3-4 months ago.
Drive along the freeway minding my own business then all of a sudden it decelerates by itself. . I panic and got out the fast lane (doing about 70 and still decelerating). Dropped it in neutral and put it back in 5th and it accelerates like everything is normal. Same thing just happened tonight. Any ideas? Thanks in advance.
Old Jan 17, 2004 | 01:44 AM
AP2's Avatar
AP2
Moderator Alumni
Do you have enough gas in your car?
Old Jan 17, 2004 | 01:54 AM
92gsr's Avatar
92gsr
lol of course i did. This is the 2nd time it has done it. You think it might be my fuel injectors?
Old Jan 17, 2004 | 01:59 AM
92gsr's Avatar
92gsr
I don't think i was very specific the first time. I was mashing gas pedal when it was decelerating but no response. It lasted for a good 5-10 seconds before everything went back to normal. Not sure if popping it in neutral and back to 5th really changed anything. It was just a desperate attempt. This is the 2nd time it has happened and it looks like its not going to go away. Please help.
AP2's Avatar
AP2
Moderator Alumni
Your fuel injectors should be fine. The electrical/ignition system would more likely to be the culprit. Does it feel like it cuts in/out when you're accelerating? Does the tach erractically swing across?
Old Jan 17, 2004 | 03:30 AM
IntegraR's Avatar
IntegraR
my best guess is Auxiliary Air Valve (Idle Speed)
Old Jan 17, 2004 | 11:00 AM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
how does your RPM's react to this?
Old Jan 17, 2004 | 12:22 PM
92gsr's Avatar
92gsr
It accelerates fine. Rpm is normal. Somebody told me to check my fuel filter. If i can find it. <------------ total noob
Old Jan 17, 2004 | 12:47 PM
kfar09's Avatar
kfar09
call up a honda or acura dealership and see if they could suggest what is wrong with it. then if the part is cheap, go buy it and replace it yourself. im sure it has happened before
Old Jan 17, 2004 | 01:45 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
A clogged catalytic converter can also cause what you're describing...
