HELP! on rear brakes
Old Jul 28, 2002 | 12:29 PM
DC2GSR's Avatar
DC2GSR
Default HELP! on rear brakes
I was wondering if someone here can help me out.
Anyways, I was trying to change the rear brakes (rotors and pads) on my 94 gsr, but I was having major problems trying to get the rotor assembly back on because the piston would not compress. So I tried using a C-clamp to compress it and it was like super hard - it barely even budged. The handbrakes were already released, so I can't figure what the heck is up with the piston. Friends tell me that the piston should just push in and out without a prob, mine obviously doesn't.
So my car is on jack stands as I speak. Any input would be greatly appreciated.
Old Jul 28, 2002 | 02:28 PM
fidracer's Avatar
fidracer
I did my front pads not too long ago and used channel-lock pliers to compress the piston. I just ratcheted them out to the widest setting, slipped them over the edge of the piston and the back of the caliper and squeezed like hell. It finally moved and slowly compressed back in.
You can't really break it so if it is moving with your c-clamp method (which is probably better than my method), just keep cranking. I hope you are using a bock of wood over the piston's edge rather than using the c-clamp on the inside backing of the piston as I don't know how strong that back face is. You might just be able to use the clamp on the edge of the piston (that's what I did with the channel-locks) because that should distribute the force better, even if it is off-center. Good luck!
Old Jul 28, 2002 | 02:53 PM
dVs's Avatar
dVs
Platinum Member
Default Re: HELP! on rear brakes
The rear pistons need to be spun. I don't remember which way (counter/clock wise) but if u look at the face of the piston it has a + sign on it. Use a giant flat head screwdriver or anything that you can use to turn the piston back into the housing. You're only supposed to use c-clamps on the front pistons.
Old Jul 28, 2002 | 03:13 PM
fidracer's Avatar
fidracer
Yep, that's right, sorry about my post. service manual says:
"Rotate the caliper piston clockwise into place in the cylinder, then align the cutout in the piston with the tab on the inner pad by turning the piston back."
Old Jul 28, 2002 | 03:18 PM
DC2GSR's Avatar
DC2GSR
Thanks for the replies,
dVs.. Thanks a million!!! I will try that first thing tomorrow!!
themonsteraria
92+ Civic/EL & Del Sol
3
Aug 21, 2009 03:36 PM
hibbarcd
3
Nov 6, 2005 05:49 AM
NoRiCeHeRe
3
Jul 11, 2003 12:32 PM
