starting problems and sprax problem
Old Dec 26, 2003 | 02:24 PM
RotaryPower88's Avatar
RotaryPower88
Default starting problems and sprax problem
ok my first problem is this
93 integra ls by the way
i came home 1 day and car was fine and went home for 30 mins come out try to go out and start the car, nothin happend. got my dad to help me push start the car and it started. shut it off and start it up for like 10 times, everything was ok. so i plan to leave and then i got tired of the exhuast rattalin, i pull the car in the garage and shut it of. i fix it and went to start it i got nothing!..
next day i push start it and did the same thing shut it of and start it 10 times to make sure its ok. i shut it of go inside for a bit then come out and start it nothin happen.. what can this problem be??
now my second problem w ith the car
when i looked under neath the back end of the car when the exhuast was rattalin i see sparx coming of the exhuast and the underneath body of the car.. it only happens when the exhuast touches the body i guess it grounds out or somethin. now i looked every were if theres a hot wire touching the body of the car.didnt find nothin, so while i was takin my starter out, i noticed as soon as i took my intake of the car i see the braided nitrous line had a black mark like it would ground out ,..i notice that it was touching the starter. could that cause the sprax to happen when the exhuast touches the body?
if any 1 is local and would like to come down and check it out i live in vineland
609-381-9804
Old Dec 26, 2003 | 02:44 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Your alternator might be bad, or there's some current not properly flowing through the car, and it's discharging when it touches the exhaust?
Dunno, that's kinda weird
Old Dec 26, 2003 | 10:53 PM
Motohip's Avatar
Motohip
And it's sparks, not sprax . It took me a while to figure out what you were trying to say
Old Dec 29, 2003 | 02:57 PM
RotaryPower88
first problem is done
now i need to find out were its grounding out causing it to sprak
Old Jan 13, 2004 | 11:09 AM
That1Guy's Avatar
That1Guy
What did you find out was the problem?
