radiator fan control module
Old Dec 25, 2003 | 08:33 PM
blackcar28's Avatar
blackcar28
Default radiator fan control module
cooling fans have gone crazy where is the fan control module located on 1992 integra? thanks if u can help
Old Dec 26, 2003 | 06:25 PM
Sam92teg's Avatar
Sam92teg
...so what are your fans doing? not comin on, not shutting off, running after the car is off, need more info
I had a problem with the cooling fan not coming on so I replaced my Engine Coolant Temperature Switch (fan switch), and its fine now.
This ECTSwitch should not be confused with the Engine Coolant Temperature Sensor. Hope this helps somewhat.
Also, there is an Engine Oil Temperater Switch that turns on your A/C fan at high temps if equiped with A/C.
I am working from memory from when I had the problem, so hope I didnt fudge anything to bad. Here is my ride-- hubcaps lol
File Type: jpg
