radiator is leaking
Old Dec 18, 2003 | 12:22 PM
NOSon's Avatar
NOSon
Default radiator is leaking
My radiator leaks from the bottom whenever i turn on the heater. When i put the climate to blue(cold) it doesn't leak. Why does this happen, do i need a new radiator?? or can i get something to seal the leak?
Old Dec 18, 2003 | 12:33 PM
Daniel's Avatar
Daniel
New radiator. OEM Integra radiators with the plastic end-pieces are prone to leakage. Buy an all aluminum radiator from your local automotive store (I bought mine from NAPA), or purchase a performance radiator, such as Fluidine.
Old Dec 18, 2003 | 12:57 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Meh... or do what I did. Find a company that would be willing to install the plastic endcap style radiator with a lifetime warranty.... For $95 :exnbp: (I bargained them down)
Though, I think this radiator will only last 5 years or so, but by then I will have either sold the car, or have enough money to go for a nice fluidyne all-aluminum...
And if I don't have enough money then, then I'll just get another free radiator to tide me over for another couple years...
Being that, if you want to go the cheap route, go here www.radiators.com
Old Dec 18, 2003 | 01:13 PM
NOSon's Avatar
NOSon
im still poor for a cheap route. the leak is on the bottom at the end of the passenger side; can i just buy some kind of adhesive and seal it up?
Old Dec 18, 2003 | 01:51 PM
Epoch's Avatar
Epoch
JB weld could possibly work, but I really doubt it... once the crack is there, it's only a matter of time until the crack goes almost the full length of the radiator... but if you wanna try the cheap route, JB weld seems like you best bet
Old Dec 18, 2003 | 02:17 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
If you're not getting a leak all the time then it's probably not your radiator that is leaking. The problem is most likely in the heater core or its associated plumbing.
Old Dec 18, 2003 | 02:22 PM
NOSon's Avatar
NOSon
it doesn't leak all the time, it only leaks whenever i turn on the heater.
Old Dec 18, 2003 | 08:49 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
And that is exactly what leads me to believe that something is wrong with your heater core or its associated plumbing, rather than the radiator.
Old Dec 18, 2003 | 09:07 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
I agree if it only leaks when the heat is on then its a heater core problem and not radiator. h:
Old Dec 18, 2003 | 09:17 PM
GRAYGHOST's Avatar
GRAYGHOST
Can you visually see the RADIATOR leaking coolant?? The heater core is in the dash i believe, so it would be hard to confuse these two.
