cat to exhaust problem
Old Nov 30, 2003 | 04:03 PM
pbizzlegsr's Avatar
pbizzlegsr
Default cat to exhaust problem
yesterday a friend and i installed my greddy evo catback..we used air tools so unscrewing was quick..the thing is..the cat has 3 screws sticking out where it connects to exhaust pipe..unscrewing the bolts..half of the bottom 2 bolts broke off along with the screw..and we were .left with the top one..im now pretty sure there has to be leaking since only 1 of 3 is screwed on tightly..the bottom 2 arent..what can i do? replace the cat?
Old Nov 30, 2003 | 06:47 PM
kfar09's Avatar
kfar09
perfect excuse for a highflow cat. go carsound
Old Nov 30, 2003 | 06:49 PM
pbizzlegsr's Avatar
pbizzlegsr
the thing is..if i go carsound..id have to get it welded on..im from CA so once smog check comes around..i cant replace it back to stock to pass..what should i do..how are the obx cats that are direct bolt on?
Old Nov 30, 2003 | 07:03 PM
kfar09's Avatar
kfar09
go to a junkyard and get one
Old Nov 30, 2003 | 07:12 PM
qtiger's Avatar
qtiger
Temporary fix: High temp gasket maker.
Old Nov 30, 2003 | 07:26 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
You can have a muffler shop weld custom flanges onto some Carsound cats (But I think Carsound cats are CARB legal?)
I got a RandomTech Cat that's CARB legal... direct bolt on, and it fit better than stock!
OBX= shit... it's a resonator, not a cat
Old Nov 30, 2003 | 08:22 PM
rgbpmp's Avatar
rgbpmp
Arent the bolts studs? You could just go get some bolts to replace them, dont even need the studs.
Old Nov 30, 2003 | 08:41 PM
pbizzlegsr's Avatar
pbizzlegsr
no i mean the 3 parts that stick out to go through the exhaust pip holes..they broke off with the studs..
