no brake piston
Old Nov 25, 2003 | 09:01 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
Default no brake piston
i was chageing my brakes today and i started to change the front.. i looked at it and there wasnt a brake piston.. any suggestions?
Old Nov 25, 2003 | 09:58 PM
Kai's Avatar
Kai
Rotorphile.
No piston, as in completely gone?
Are you sure it isn't just stuck in there? It should be a major hydrolic leak if there was no piston.
Old Nov 26, 2003 | 09:00 AM
Spec R's Avatar
Spec R
Thats kind of scary. Take a picture if you can.
DB Squad
Integra Forum Moderator
Old Nov 26, 2003 | 09:57 AM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
yeah i'll get a digital if i can.. i jjust looked at my other front brakes.. they are both gone.. my brother was like.. WTF where is that thing thats suppose to be there.. cause he has an integra and changed his brakes before..
nothings leaking .. its all dry.. all metal
Old Nov 26, 2003 | 10:28 AM
Daniel's Avatar
Daniel
The piston is hollow! Look at it, you should see the caliper housing, then a spherical rubber seal, followed by the spherical caliper. If the caliper is stuck out, compress them back in using a c-clamp, then step lightly on the brake pedal again but do not go to the floor, just enough to note movement. You will see the caliper slide back out. If there were no calipers there, you would not have any brakes and you would have wrecked a long time ago!
Old Nov 26, 2003 | 02:38 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
hmph.. i must double check again.. now looking closer at the picture i get what you guys are talking about.. i feel like an idiot h:.. thanks drumsy.. i have just been critisized all day
Old Nov 26, 2003 | 03:14 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
:chuckles: that was a good one...
Old Nov 26, 2003 | 03:29 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
hey hey.. we all learn one way or another! h:
Old Nov 26, 2003 | 03:32 PM
SUPER LAUBO
KiMBO's Hubby
no harm no foul, i would have thought the same thing back then..
Old Nov 26, 2003 | 05:14 PM
Spec R's Avatar
Spec R
yeah, i was gonna say, with the brake pads out, the we see the bottom of the piston, which is like a hollow cylinder.
DB Squad
