Timing Belt Tensioner Pulley
Old Nov 24, 2003 | 09:54 AM
Dintegra97's Avatar
Dintegra97
Default Timing Belt Tensioner Pulley
Im trying to get the tensioner pulley off of my b18b. Everytime i try to get the bolt off of it tho it starts to strip it. Is there a trick to getting it off. Any info would help. Thanks:thinking:
Old Nov 24, 2003 | 09:57 AM
JimBlake's Avatar
JimBlake
The only trick I know is using a 6-point socket (not 12-pt) and holding it straight & square to the bolt. If you've already rounded off the head of the bolt, you're gonna have fun getting it off. When you do, get a new bolt...
Old Nov 24, 2003 | 10:21 AM
Dintegra97's Avatar
Dintegra97
its not rounded off yet. it slipped like twice and then i stopped. Ill just keep trying i guess
Old Nov 24, 2003 | 10:31 AM
integboy97's Avatar
integboy97
i had the biggest pain in the ass trying to get mine off too! the only thing i know is to use a 6 pt socket instead of a 12 pt like jimblake said:dunno: sorry i couldnt be more helpful
Old Nov 24, 2003 | 01:14 PM
JimBlake's Avatar
JimBlake
Most sockets are kinda rounded at the end. The best thing would be get a 6-pt socket, and grind the end down just enough so it's sharp & square inside. Then hold it in hard against the bolt as you try to loosen it. Yes, I know there isn't enough room to get in there & hold it...
Ummm - counterclockwise! That bolt IS a right-hand thread.
Old Nov 24, 2003 | 07:00 PM
sff900's Avatar
sff900
if you end up stripping it pick up some stripped bolt removing sockets from craftsman 10-15 bucks totally worth it
Old Nov 24, 2003 | 07:02 PM
XSrcing's Avatar
XSrcing
buy a set of snap-on flank drive sockets. you wont have this problem any more!
Old Nov 24, 2003 | 09:47 PM
forum95's Avatar
forum95
I'm Cooler than You
Yep you gotta press extra hard and straight when you try and losen stuff like that.
Old Nov 24, 2003 | 11:01 PM
IntegraR's Avatar
IntegraR
Default Re: Timing Belt Tensioner Pulley
USE WD-40!
Tensioner Pulley Adjusting Bolt 40 ft.lb
here is a picture look in the upper right corner!
tensioner
