HELP!!! CD replacement.. how to get my stock one out
Alright, can anyone give me detailed steps to follow on taking out my stock tape deck? i looked all around, even yanked on that thing, i need help, any details will help
Platinum Plus Member
I think start out by taking out the ash tray and removing the two screws in there (maybe 3 cant remember). Once you have that pulled out then look inside the opening for a screw that looks like it is holding in the CD player. Undo that and it should free the player. But this was for a 95 RS , not knowing what you have its hard to give instructions on what to do
it's a 92 integra ls... i think i've found two screws the go from the harness to the player itself holding it together, tried to unscrew but too tight... is there any part of the dash i can take off to make it easier to get to the screws?
Remove the console.
Remove the 2 screws and pull the unit out.
Disconnect the harness plugs and remove the unit.
Install in reverse order. Enter the security code.
Thats all i can find
KiMBO's Hubby
most likely you'll have to take the two screws out from behind the radio.
the newer integras have 2-8mm bolts holding it in, but the older ones use 2-phillips screws. i suggest going to a hardware store and buy a Skewdriver with a long phillips bit that fits the screw head snug. once you strip out the head, you are in for some massive drilling work.
~~~edit~~~
NEVERMIND..wrong car :doh:
~~~edit~~~
I miss my 93 VTEC Lude :(
bottom line
Teggys suck for new headunits
i broke mine.....now the dash kit doesnt sit as secure as its supposed to :/ wonder how much new parts will cost.
