Upper Balljoints
Upper Balljoints
ok, so what has everybody done when the time to replace upper balljoints rolls/rolled around?
i understand that acura only sells the upper control arm! but also realize that the balljoint CAN be replaced-just wondering what everybody else did.
also, as for lower balljoints- what do we do for those? oem? moog? whats the best.
havent done too much looking into this aside from a few searches-so hopefully someone can give me some good information!
Paz
Paz
bottom ball joint can be replaced. moog works fine.
for the top you'll need the oem arms. you can press the old worn out joints out, but i don't know who makes replacements.
bet bet is this:
upper balljoint: replace the upper a arm
steering endlinks: replace endlinks
bottom balljoint: replace with either oem or cheap aftermarket pieces
both work fine.
bet bet is this:
both work fine.
Wannabe yuppie
Yeah skunk2 sells replacement A-arms that have adjustable ball joints which allow you to adjust the camber. Not sure what the price difference between those and OEM is though.
well both the skunk2's and those other ones are for DC chassis. ive got a DA.
the only ones like that ive seen for my chassis were by vision for $320 a set
these'll probably be the route i go, they sure do look purdy!
Paz
Paz
so orijin makes control arm bushings? well thats good i guess, i was talking about balljoints though.
(were now talking about the green things right? )
whats the deal with those things anyway-dont camber kits come with theyre own bushings anyway?
Paz
Paz
Wannabe yuppie
If you buy a camber kit like the skunk2 that includes the entire control arm then it will come with bushings. Most camber kits are adjustable "bolts" that go in place of the bushings and allow you to change the distance between the control arm and the body of the car.
:thumbup:
