possible del sol
Old Nov 13, 2003 | 08:53 AM
im20011376's Avatar
im20011376
Default possible del sol
if i were to use a b20 out of a 97 crv and a gsr gead what would be the approx hp/torque with as much stock internals as possible(without the motor being unreliable) and just a header, exhaust and intake? would this be an acceptable swap for a del sol?
Old Nov 13, 2003 | 11:14 AM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
just know you would have yourself a high reving engine. All stock internals should be fine (use the b18 crank) just as long as you dont beat on it daily. I have no idea what the hp/torque would be. Dyno it and tell us As far as it going into a Del Sol...anything can be done with enough money :thumbup:
Old Nov 13, 2003 | 11:16 AM
Snoopy's Avatar
Snoopy
been there done that
not really. you'd be limited to the b20's redline with stock internals. b18b and b20b cranks are the same.
Old Nov 13, 2003 | 11:22 AM
Shore 96 Teg
ok then would a b16 head on a b20 block produce higher revs???
thats what i heard from this guy I work with. i was just kinda applying what he told me about a b16/b20 to a b18/b20.
Old Nov 13, 2003 | 04:10 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Hold on a minute... :eh:
1) The head will affect high rpm efficiency, not physically limit the motor from revving.
2) The B18B or B20B/Z internals are kept to a lower rev limit, by the ECU for a good reason.
3) My honest opinion on CRV / VTECs and other Frankensteins is that you're better off buying a B18C and Sleeving it out to 2.0L using the Darton or AEBS sleeve replacements.
Then:
a) add high-c/r forged pistons and rods for an NA build up.
or.
b) low-c/r forged pistons and rods for turbo applications.
Basically, if you want to have a VTEC B that is as reliable as a stock B18C5 (for example), then it is best to start out with a VTEC motor, rather than do things cheaply.
A powerful, reliable small displacement motor costs serious money. It's one of the universal truths in auto performance.
Old Nov 13, 2003 | 05:25 PM
Snoopy's Avatar
Snoopy
Then:
or.
right on :rockon:
Old Nov 14, 2003 | 07:44 AM
im20011376's Avatar
im20011376
what kind of figures would the 1.8 slleved to 2.0 produce?
Old Nov 14, 2003 | 11:42 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Then:
or.
Amen! Well put:thumbup:
Old Nov 14, 2003 | 02:49 PM
TheOtherDave™
Apathy Kills
Originally posted by Snoopy
right on :rockon:
Thank you both very much. :cheers:
Old Nov 14, 2003 | 03:25 PM
Snoopy's Avatar
Snoopy
all these what if questions will vary depending on what internals you're using.
