Noise from my engine.
Old Nov 4, 2003 | 11:49 PM
94nteg's Avatar
94nteg
Default Noise from my engine.
I have a 94 gsr with 140k miles. A few months ago, my engine started making an unpleasant sound. It sounds like a belt noise, very rapid (about 4 beats per second) and low pitch. A friend said it sounds like the lifter has gone bad. Has anyone else had a similiar problem, and what did you do to correct it?
Old Nov 5, 2003 | 12:31 AM
APx's Avatar
APx
Does the noise go away at high RPMs? and return at idling RPMs?does the noise happen when you start the car? etc...
And anymore info you can give would be helpful
The only thing I can think of would be loose or a dry belt but I need more info
Old Nov 5, 2003 | 02:43 AM
g2tegls's Avatar
g2tegls
MR, ftw
Default Re: Noise from my engine.
wht the hell is the lifter?
Old Nov 5, 2003 | 02:44 AM
g2tegls's Avatar
g2tegls
MR, ftw
sounds like maybe you need a valve adjustment though. :thinking:
Old Nov 5, 2003 | 09:48 AM
94nteg's Avatar
94nteg
The sound is very prevalent when the car is idling. I can't say for sure if the noise goes away at high rpm. Even if the noise is still there, the regular engine and exhaust noise drowns it out so I wouldn't be able to tell. It's not the belt because I can see that the sound is coming from the engine, but it does sound similar to a sound that you would get from a problematic belt.
Old Nov 5, 2003 | 09:52 AM
94nteg's Avatar
94nteg
Default Re: Re: Noise from my engine.
I don't know either, that's the term that my friend used, and he is a mechanic.
Old Nov 5, 2003 | 09:53 AM
blazinxracer's Avatar
blazinxracer
mine is doing the same. xcept mine does it when it feels like it. like it will be ok for days and then one day i will be there idling and it will come back. i was thinkn about changing te belt ne ways cuz im at 37k so it about time for that anyway. there was a similar post u might want to search but i dont thnk it found the xact solution
Old Nov 5, 2003 | 10:56 AM
newgsrdriver's Avatar
newgsrdriver
When you say a problematic belt, do you mean a squeak?
Old Nov 5, 2003 | 05:56 PM
gno038's Avatar
gno038
its probably your valves tapping. = valve adjustment
