Tein Springs too low?
Does anyone have experience with Tein S-Tech lowering springs? I have 215/40/17 tires on a 00 GSR. These springs give a 2.6"F/1.75"R drop. I measured my wheelwell gap, and it would be REALLY close. These springs are supposed to be good, do you think they'd fit? I plan to use them with Koni Reds.
Thanks
Thanks
Thanks
Thanks
With your 17's they'll rub for sure. Just to let you know the spring rates are real soft on those S-techs (aka stylish techs), something like 250lbs front, 137lbs rear, which is pretty close to stock. Get a set of H&R Sports, they'll suit your needs best. The Race springs will drop u too low.
DB Squad
Integra Forum Moderator
DB Squad
Originally posted by tirod²slc
what if he wants a stock ride just lower?? :wiggle:
DB Squad
DB Squad
Thanks guys!
I was looking to drop the car around 2" and get better handling characteristics without being TOO stiff. Besides Tein, I was also considering HR sofsports, Eibach pro, or Comptech. The comptech are only 5% stiffer than stock, so probably the Eibach or HR. I also plan to use a skunk2 camber kit and koni reds so this is done right the first time. No bouncing around or negative camber on the stock equipment
I appreciate your input on this
any drop will make you rub on those 215 tires. i have 215's on my car with the H&R race springs and I rub ALL the time. Once these tires are used im gonna get 205s and they shouldnt rub at all.
Thanks guys!
Thanks guys!
DB Squad
DB Squad
Thanks guys!
Thanks guys!
I'm running H&R Sport on Koni Yellows and it dropped my car 3", yes 3", while the spring rate is only 276 lb/in... the ride SUCKS on bad roads. :eh:
Originally posted by PatrickGSR94
You don't want zero camber, handling will suck. Dial it in to around -1.5 or so.
DB Squad
DB Squad
