difference between bolt on and weld on mufflers?
is there any difference? how hard is it to install a bolt-on muffler?
i can assume that weld-on will require a lot of equipment.
Chop Shop Street Team
bolt on mufflers are a lot easier to install and they are worth the extra money, simply because of less headaches. universal mufflers cost a lot more to install cause unless you know how to weld and own welding equipment, you are going to have to go to a muffler specialist to get it installed, which is going to cost a pretty penny.
if I buy one of those cheapass no-name mufflers on ebay, will they fit on my car without any mods?
also I have almost no experience with handling tools. Is it pretty easy to install a new muffler?
JDM rox ur world
bolt on is better...BUT..if your car is as old as mine 95...when i got my bolt on i couldn't put it on because i couldn't break the bolts loose..i tried everything and i'm pretty damn strong..same goes for my rear struts..i can't get the bolts of to install rear coilovers
JDM rox ur world
Honda bolts will always snap...they're crap. I suggest buying new ones from Acura BEFORE trying to get any off so if (when) they break you won't be screwed until you can get some new ones.
