skunk2 short shifter problems
I installed a B&M short shifter in my GS-R and it rattled. i found out 99% of people with that shifter had the same problem. so i get a skunk2 shifter. well the stock shift knob doesn't fit. I was pissed at that because i thought skunk2 made it so only the skunk2 knob will fit. so i order it anyways. and it finally gets here and it doesn't fit right either. so i call up the place where i bought it to see what's up. and they say they get a call about that alot. after skunk makes the threads they spray a coating over the whole thing. so they say it will fit i just have toi get the knob on once it it will go off and on all day. so i try that it goes down a little and won't move anymore. so i try to back it off and it won't come off either. thats where i am now and oh yea the skunk2 shifter rattles too not as loud but it still does. **** B&M and **** skunk2 :madfawk:
I also have a Skunk2 shifter. I also had the problem with my shift knob not fitting on the shifter. I have the skunk2 shift knob as well. I thought the shiftknob would be a perfect fit with the shifter, since they are from the same company, but it didnt fit. I called the place where i bought the shift knob from and they said the same thing about the coating that acuradriva had mentioned. They told me to put a little muscle into it and it should fit. After doing that, i decided that coating the thread on my shifter and my shiftknob with some grease should make it easier to screw the shiftknob on. It worked. So i suggest if you are unable to screw the shift knob on, put some grease on the thread of the shifter and shiftknob, and it should fit.
i installed the skunk2 short shifter w a friend and it doesn't rattle at all.. i also have the skunk2 shift knob and this is what i did to get it on. at first it wouldn't go so i tightened it down til it stopped and then backed it off and i kept on doing this pushing it down a little bit further and finally it went on all the way. just try working with it
