Fuel pressure regulator?
Old Sep 5, 2003 | 01:48 PM
Slacker's Avatar
Slacker
Default Fuel pressure regulator?
OK I think my problems all go back to me running rich. I've been talking with some good mechanics and they said all my symptons have one common thing. They can all be caused by running to rich. Therefore, I need a regulator to turn down my fuel pressure. I know there are only a few that will do this, most just go up? What are they and where should I get it from.. price would be helpful too
Old Sep 5, 2003 | 04:01 PM
dantastic's Avatar
dantastic
cx power!
get a b&m fpr modifier and guage. i got them both from summit. ~$80 i think.
Old Sep 5, 2003 | 04:24 PM
Slacker's Avatar
Slacker
It will allow me to turn the pressure wayyyy down?
Old Sep 6, 2003 | 07:05 AM
oc_civic's Avatar
oc_civic
mcc racing
yes.. B&M vortech.. they are all the same.. but they are hard adjustments.. as in if you are CONSTANTLY running rich then it would be a good choice.. if you are fin at some pms but lets say rich at idle and partial throttle you should invest in something more..like a vafc.. you can adjust the fuel + or - 50% per 500 rpms.. and i USED to have a fuel pressure gauge under the hood.. it sucked.. becuase you could not see ti during driving conditions.. but that alone will not help you.. you are haveing a tuning issue.. from what you say.. the pressure gauge alone will not solve the issue.. id invest on an in car fuel pressure gauge.. like the one i have (autometer mechanical pressure gauge and an isolator) and an egt... then you really can tel if you are trully running rich..
Old Sep 6, 2003 | 10:55 AM
ManTiS's Avatar
ManTiS
NinJA
It was to my understanding that the B&M one only raises pressure.
Old Sep 6, 2003 | 11:07 AM
oc_civic's Avatar
oc_civic
mcc racing
my vortech one (which im pretty sure is a rebadged B&M one) modifys the stock one and CAN bring lower than stock fuel pressure.. granted i dont know HOW low.. i know it CAN go slightly lower..
but back to what i said ealier.. just blindly lowering the fuel pressure IMHO is not the best answer
Old Sep 6, 2003 | 05:02 PM
Slacker's Avatar
Slacker
Ok so what exactly should I get? I like the idea of being able to adjust the pressure from inside the car. How much and who makes it/sells it?
Old Sep 6, 2003 | 05:28 PM
dantastic's Avatar
dantastic
cx power!
why dont u get a fuel pressure guage first, before u buy a fpr so u can tell if its a fuel pressure prob
Old Sep 7, 2003 | 07:04 PM
kingk7's Avatar
kingk7
go to summit and order the b&m cammand flow fpr, and the b&m fuel pressure guage. then you are set and you can adjust you pressure to whatever you want.
Old Sep 7, 2003 | 09:03 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You can't adjust it to whatever you want, there are limits. I run the b&m gauge/modifier and it works ok. I'm not really understanding how the gauge reads the pressure cause it sits on top of the fuel filter. Wouldn't that read how much pressure your fuel pump is pushing out? It may be a simple answer, but it doesn't register with me.
Anyway, yes, the B&M will allow you to lower/raise your pressure as you need. At a stock, non boosted B18C, it will give you the adjustment you will need.
Do you happen to have an Air/Fuel gauge? If not, it's a good way to see what you're running and know what type of adjustments need to be made.
A VAFC is not the answer for you. It's pretty useless when running stock injectors and a pretty stock motor.
What problem are you having anyway?
