Clutch Pedal clicks
Old Jul 13, 2002 | 08:05 PM
integranator's Avatar
integranator
Default Clutch Pedal clicks
When i press my clutch in, it clicks, sounds like the springs are compressing weird? When i let it out FULLY then it clicks a couple more times. Just started happening. Anyone have any idea what it could be?
Old Jul 13, 2002 | 08:29 PM
dubcac's Avatar
dubcac
I
It sounds like the pressure plate springs possibly. My old stock clutch did that, but only once on the way out, and I could feel it in the pedal too. My clutch was already slipping however, so I had to replace it regardless. The new act doesnt do it at all.
Kaiz's Avatar
Kaiz
Default Re: Clutch Pedal clicks
Wow, you're in luck cause I had the same problem a few weeks ago. Unfortunately, you are out of luck if you don't have a warranty left cause the dealer pretty much put in a new pressure plate, flywheel, friction plate (clutch), etc... and it fixed the problem. I'd say its the pressure plate, and getting that replaced is not going to be cheap. (~$1000)
Old Jul 13, 2002 | 09:09 PM
integranator
oh wow, i'm not in luck What should i do, should I deal w/ it?cas' the clutch feels fine?
Old Jul 14, 2002 | 08:22 PM
TotoTeg's Avatar
TotoTeg
I'm having a similar problem right now as well, I have determind that its either something related to the throw out bearing, shift fork, or the preasure plate.
So i have decided to bite my lip and get a new Clutch..
bjchoi
Accord
6
Mar 1, 2005 04:26 PM
TyPe_R_GuY
6
Mar 16, 2004 09:26 PM
diviculo
92+ Civic/EL & Del Sol
Nov 28, 2003 05:12 PM
