axle help
Old Aug 22, 2003 | 02:29 PM
shawn_crx8891's Avatar
shawn_crx8891
Default axle help
can i use a 90-93 driver side axle on my 1st gen b16a with the b16a intermediate shaft? i have the b16a axles but the one is bad and i'm just looking to replace it. thanks.
Old Aug 22, 2003 | 08:07 PM
jlicrx's Avatar
jlicrx
http://www.hasport.com/News/Articles...rt%20Axles.htm - you should be able to tell from this which axle you need
Old Aug 23, 2003 | 05:36 AM
shawn_crx8891
thanks
Old Sep 15, 2003 | 12:29 PM
atimberl's Avatar
atimberl
Default b16a 2nd gen axle?
I just put a jdm b16a into my 95 civic with 94 gsr axles and it seems that the driver side is like an inch too short. The boot looks stretched and when I put the car in the air the transmission side of the axle (on the intermediate shaft) was actually coming out. Did I get the wrong axle? Thanks
Old Oct 15, 2003 | 04:38 AM
norman's Avatar
norman
Default axles
i did the same swap in my 1997 civic you can use the delsol vtec to i think there the same as the gsr axles i should work with the swapmine did i hope this helped
Old Jan 7, 2004 | 07:31 AM
1995 B16A's Avatar
1995 B16A
Does anyone know where to get B16a axles cheap??? Can't afford much, but UV joint busted on me last night
THANKS!
