Changing spark plugs (easy)
I feel like a complete idiot, but I need to change my plugs, and I can't figure out how to get the wires off to access the plugs. I pulled and pulled, and only succeeded in pulling the boot off. How do I get the wires off to get to the plugs???
it does pop right out but a little twist helps it out sometimes, just yank on the spark plug boot not the wire or else u can damage the wire if u yank really hard, its like a vacume cleaner plug u can just yank it out but its not suggested
It sounds like the wire is corroded to the plug. This is not good, however easy to fix.
Step 1) Grab the plug wires with vise-grip pliers and rip them off.
Step 2) Unscrew and remove sparkplugs.
Step 3) Replace the plugs and wires with new, quality parts.
YMMV, be gentle as nessicary.
Done.:thumbup:
Done.:thumbup:
Definately dont put anti-seize on you plugs. ANti-seize is not made to handle temperatures that high it will melt and get so damn hard you'll have a harder time geting them off then your having right now.
