Vtec burning oil
Old Aug 18, 2003 | 11:08 PM
thx247's Avatar
thx247
Default Vtec burning oil
When I hit 4400+ I get a big cloud of soot and shit behind the car. This is most likely oil burning.
But it only happens when I hit the big cam.
I don't know how else I could be burning this much oil but only in vtec. Its not like there is a magical oil hole that opens up and dumps into my exhaust when I hit 4400, so any ideas on what it could be?
Old Aug 19, 2003 | 08:18 AM
Daniel's Avatar
Daniel
What color is it? Blue?
A common problem with DOHC VTEC engines is the cam seals which can cause oil leakage. While this may not be the particular fix for your problem, you may want to look also at getting a compression check done to determine which, if any or all, of your cylinders have low compression. Then, I'd start saving for new piston rings and a possible rebuild.
Old Aug 19, 2003 | 07:16 PM
thx247's Avatar
thx247
compression is 210-210-212-210.
Grey blue, obviously oil.
Cam seals- this is not an external oil leak right? I am def not leaking oil outside of the engine.
Old Aug 21, 2003 | 04:11 PM
thx247's Avatar
thx247
nothing ?
Old Aug 21, 2003 | 05:51 PM
dubcac's Avatar
dubcac
I
Valve stem seals? Oil pressure does go way up in VTEC, which causes it to burn oil.
Old Aug 23, 2003 | 06:38 PM
Sleeper98GSR's Avatar
Sleeper98GSR
LS stylee y0h
Dubster- You hit the nail on the head. I find I only burn oil in VTEC as well, though no smoke comes out.
Old Aug 23, 2003 | 06:41 PM
SilverCel's Avatar
SilverCel
Yea no smoke comes out. But you can sure smell it sometimes.
Old Aug 23, 2003 | 11:17 PM
pomansouth's Avatar
pomansouth
heh i agree with that one cause i hate that smell for some odd reason.
