Digital Guages instead of Analog
Old Aug 17, 2003 | 08:48 AM
THA ELuDA's Avatar
THA ELuDA
Default Digital Guages instead of Analog
i dont know if i should put this question in the tech room, but scince i want to do this to a teg im going to put it in here. Is it possibe to take out the analog guages in your guage cluster stick an LCD in there that reads out all the reading that you want but you would be able to adjust it to show what you wanted at certain times. For example could you have it show just miles per hour and then change it to show miles per hour, oil temp, and turbo all on the same screen. About all those reading at the same time i was just seeing if it was possible. If i should be asking this in the tech thread just tell me.
Thanks
