F-rankenstein engine
Old Aug 16, 2003 | 03:54 PM
Vinnyd's Avatar
Vinnyd
Default F-rankenstein engine
everyone knows about ls/vtec and crvtec but does anoyone know if it is possible to do a frankenstein type swap with a the f series engines. F22 block from an accord with the f20c from the s2000. I know some work would need to be done to get the compression ratio up there and allow it to rev higher.
any thoughts or ideas??
Old Aug 16, 2003 | 05:00 PM
Snoopy's Avatar
Snoopy
been there done that
f22 block with f20c head? wont work. the f20c spins the opposite direction from the f22
Old Aug 17, 2003 | 04:11 AM
drift's Avatar
drift
Flaccid Member
bore diameter is also different
F22B = 85mm
F20C = 87mm
Old Aug 17, 2003 | 04:12 AM
drift's Avatar
drift
Flaccid Member
that's simple... regrind the cams for the opposite direction
Old Aug 17, 2003 | 01:05 PM
Vinnyd's Avatar
Vinnyd
so the verdict is yes, yes and nto worth the trouble/$ or no
Old Aug 17, 2003 | 04:47 PM
drift's Avatar
drift
Flaccid Member
not worth the trouble or money.
Old Aug 25, 2003 | 12:34 PM
wadzii's Avatar
wadzii
fear the dark side
it wont work... f20c has a timing chain that runs through the head.
if you wana do something w/the f22, get a f22a1 block, stick a h22 crank and rods in there, get some forged pistons and a 1gdsm turbo manifold and boost the piss out of it
Old Aug 30, 2003 | 09:05 PM
Kai's Avatar
Kai
Rotorphile.
The F22 has a "standard" F series head design. The F20C has a head pattern that is very similar to K series engines, supposedly a K series head gasket will work on it. If that is true, they are not even close to working together.
We already have mini-me D-series, Frankenstein B series, unnamed H-series, and unnamed K-series hybrid engines... what do you want another for?
Old Aug 31, 2003 | 04:37 AM
drift's Avatar
drift
Flaccid Member
dont forget the frankenstein F series: F20B head on an F22 block
Old Aug 31, 2003 | 11:12 AM
Kai's Avatar
Kai
Rotorphile.
H series (F20B) heads bolt to F series blocks? That's new to me.
