checking oil
Old Aug 7, 2003 | 09:30 PM
Amirked's Avatar
Amirked
Default checking oil
HOW DO YOU DO IT? I let it run for a few minutes then let it sit for a few then check it on level ground. . my gf's dad saw me doing that and he said its wrong- that i should check it when its been sitting for hours not after it was just running . . what way should i do it?
Old Aug 8, 2003 | 12:36 AM
Spec R's Avatar
Spec R
even if i let my car sit for an hour, its still not the same as 3 hours. the difference is as much as half a quart on the indicators.
DB Squad
Integra Forum Moderator
Old Aug 8, 2003 | 07:49 AM
95GS-R's Avatar
95GS-R
Um What?
best time to check your oil level is in the morning when before you start your car. The full level is supposed to indicate how much oil should be in your engine once it has drained from every nook and cranny down into the oil pan.
Your gf's dad is correct, you're doing it wrong.
Old Aug 8, 2003 | 07:57 AM
Vektra's Avatar
Vektra
Let it run to check transmission fluid, you want it as cold as possible for oil because ti oil will stay in the engine so it will not be correct.
Old Aug 8, 2003 | 08:06 AM
UpStateGS's Avatar
UpStateGS
Yeah that's correct, I let it run before I change the oil.
