Leaking distributor
Old Jul 18, 2003 | 06:42 AM
ikarma's Avatar
ikarma
Default Leaking distributor
My distributor is leaking inside. Can I just tear it down and replace the o rings inside, or do I need to replace the entire housing? If I can replace the o rings how many are there? I see one on the outside shaft how many more are inside?
Oh yeah, its a 95 Civix DX (D15b7)
Chris
Old Jul 20, 2003 | 12:43 AM
jackasssi's Avatar
jackasssi
Allstar
There is 1 more o-ring behind the thrust washers. Usually the whole distributor will need replacement when an internal leak occurs.
