Accord injectors in H22a in 5th GEn Accord
Would this cause a misfire? We seem to be having a problem with random misfires at idle. I'm sure they occur high in the rpm band, but we can't hear or feel them in anything other than idle. I would assume, that a smaller injector might starve the engine of fuel and cause misfires.
we have to get the correct injector resistor box. So we will see how this turns out when it comes in. The accord box won't fire the prelude injectors. ObdII car and harness, OBDI engine and injectors.
Thanks for you help.
What do you mean the accord box won't fire the injectors? Are you talking about the resistor box cause those boxes are teh same for all cars I thought the same thing and bought a prelude one and the resistance was 5.8 ohms on both packs so it must be something else. Also what is your set-up car engine and what computer are you using?
Accordhybrid
Accordhybrid
