rockford fosgate punch 800a4 configuration?
Old Jul 16, 2003 | 10:30 AM
ClayMan's Avatar
ClayMan
Default rockford fosgate punch 800a4 configuration?
First of all, any testomonials about this amp?
I have 2 400W RMS, 600W max, 4ohm 10" Kenwood subs. They're sorta old, probably from the 90s so I think they're single voice coils.
if you look at the specs of the amp here:
http://www.levinelawonline.com/Rockf...ower_800a4.htm
it says that bridged, it can do 400W x 2, which would be perfect for my subs right? however it says that it's stable into 4 ohms in mono mode... my subs are 4 ohms, but I also remember reading somewhere that when bridged, a 4 ohm load reads as 2 ohms to the amplifier. can someone verify this? would the amp be stable running 400W monoi bridged into 2 separate 4ohm subs?
Old Jul 16, 2003 | 11:00 AM
jhargrove's Avatar
jhargrove
I can help ya here. I have the 600a4, two channels running my components, the other two channels bridged to one sub. I will assume you want to bridge your amp from 4 channels to 2 channels.
Since you have 2 subwoofers, each one being 4 ohms, you should bridge the front channels (left & right) together and put one sub on it, then bridge the rear channels (left & right) together to power the second sub. You will NOT connect the two subs together; they are run independently of each other.
In this configuration, you will put a 4 ohm load on each bridged pair of channels, which is FINE.
Hope this helps.
Old Jul 16, 2003 | 11:40 AM
b00gers's Avatar
b00gers
jhargrove is right. you are not bridging the subs together. you are bridging the channels on the amp.
so you would want this:
ch 1 = positive from sub #1
ch 2 = negative from sub #1
ch 3 = positive from sub #2
ch 4 = negative from sub #2
