WHO MAKES the best ADjustable Cam Gear for 98 civic ex SOHC?
My question is: Why do you want one? On a SOHC motor, without FI it won't make a HUGE difference messing with the timing. On the DOHC models they adjust the cam overlap and can produce sick results. Save your money and buy a shot of juice or something.
Rotorphile.
The problem with an adjustable cam gear on a SOHC is that you are adjusting the intake and exhaust timing at the same time. This makes it not nearly as useful for the money as a pair gears on a DOHC, where you can independantly adjust the intake and exhaust timing.
For best results, you need to have it dyno tuned, which also adds to the overall HP/$ cost. You really won't even notice a difference without other modifications, ideally the gear is added at the same time as an aftermarket cam... so you can time the new cam to give its highest output.
