Throwing code 22 (vtec oil pressure) on b18c swap
Old 07-12-2003, 12:12 PM
DVPGSR
I need sleep...
DVPGSR's Avatar
Default Throwing code 22 (vtec oil pressure) on b18c swap
This is Slacker.
I am throwing code 22 (vtec oil pressure) on 96 jdm b18c in a 99 civic ex. I am running a obd1 usdm p72 ecu. Need help resolvig this issue.
PS. I know the jdm motors did not come with this sensor.. but how can I "trick" the computer into not looking for it so vtec will work? Thanks!
Old 07-12-2003, 12:47 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Take out the CEL bulb. :db:
That's a good question. If I had any experience with the JDM motor I would help you out.
Why would it not have it? Isn't that how it engages VTEC is by reading that sensor? If it doesn't have it, how does it know when to engage? :dunno:
Old 07-12-2003, 12:54 PM
oneslodx
oneslodx's Avatar
ummm i just put a 95 B18C in my car and it had a vtec oil pressure wire. its a jdm motor. so i donno
DVPGSR
I need sleep...
DVPGSR's Avatar
No the sensor just makes sure vtec doesn't engage without the correct oil pressure (no damage to engine). So in other words in won't engage without the sensor. Like I said the jdm motors don't have it.
Old 07-12-2003, 12:55 PM
DVPGSR
I need sleep...
DVPGSR's Avatar
It has the wires, but there is no senosr on the obd2 jdm motors.
Old 07-12-2003, 12:56 PM
oneslodx
oneslodx's Avatar
if it doesnt engage without the sensor and JDM motors dont have the sensor then wouldnt that mean jdm motors cant use the Vtec????????? and my jdm motor had a vtec oil pressure, i know it for a fact bc i had to wire that the vtec solenoid and knock sensor directly to the ECU and i did it this past week
NeverBX
Snootchie Bootchies!!
NeverBX's Avatar
are you saying that you have a jdm motor, too and it has the sensor? or are you just saying that your usdm motor doesnt have one so you dont know?
Old 07-12-2003, 12:57 PM
oneslodx
oneslodx's Avatar
oh ok...... thats still surprising
NeverBX
NeverBX's Avatar
sorry post was late.
oneslodx
oneslodx's Avatar
i have a JDM motor, but it is an ODB1 so i donno if there is a difference because of that or not? but mine has that sensor
