Engine starts then dies
Old 07-11-2003, 06:45 PM
hyisbm
hyisbm's Avatar
Default Engine starts then dies
I need help figuring out what's wrong with my car. I haven't been able to use it for over a week now. At first, I couldn't get the car to start at all. It would still crank but never start. I already got new spark plugs and fuel pump installed and now have a different problem. If I leave it in neutral and start, I can start it but within a second, it will die. If I was to leave it in first-gear and start it, it will stay on. The only thing my brother can think of it is maybe the main relay, something with the fuel or the timing. What do you guys think could be causing the problem? I really need to take care of this. Thanks
Old 07-11-2003, 07:33 PM
sts2poc1
sts2poc1's Avatar
coil??? electronic control modual???
Old 07-11-2003, 07:58 PM
qtiger
qtiger's Avatar
First starts but neutral doesn't? Are you sure you didn't get it backwards?
Old 07-11-2003, 08:06 PM
hyisbm
hyisbm's Avatar
in neutral, it starts but then dies within a second
leave it in first gear to start, then it stays on. once it's on, i can put it in neutral and it will stay on
would reseting the ecu do anything?
Old 07-11-2003, 09:25 PM
PHiZ
BOOST GOD
PHiZ's Avatar
is it the proper ecu for the car?
Getting any CELs?
Have you done any work on the car recently?
-PHiZ
Old 07-11-2003, 09:28 PM
Ferio Man
Ferio Man's Avatar
Getting any CELs?
-PHiZ
also has any mechanic touched your car lately?
Old 07-11-2003, 10:00 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
Is this an auto?
Old 07-12-2003, 07:00 AM
PHiZ
BOOST GOD
PHiZ's Avatar
Originally posted by Bakeoff
Is this an auto?
Ahhh, now we're getting somewhere. I was asking questions no a similar track, but again, I have to make things like one billion times more difficult.
(I was wondering if he did something with swapping the ecu,and was getting a weird problem with the auto lockup solenoid.)
Bakeoff :thumbup:
-PHiZ
Old 07-12-2003, 07:40 AM
hyisbm
hyisbm's Avatar
My car is a 93 ex manual. The only modification is a cai but this problem has been starting before any modifications already.
Old 07-12-2003, 07:50 AM
ManTiS
NinJA
ManTiS's Avatar
Any CEL?
Also, check your spark plug wire order.
