A/C Belt increase HP???
Old Jul 9, 2002 | 08:17 AM
accordtunerx's Avatar
accordtunerx
Default A/C Belt increase HP???
The other day, someone told me that if I cut the A/C belt on my 92 accord...then I would get like 20-25 HP gain. Is this true?
Old Jul 9, 2002 | 08:42 AM
JCAB's Avatar
JCAB
you would free up some power yes, but it would be nowhere near 20 Hp. I would guess more around 2-5 or so. But I wouldn't worry about it. Some cars disengage the A/C drive pulley at WOT, so this isn't even an issue, because the only time you are going to be using that last 2-5 hp is at WOT.
I am not sure if Honda is the same way though. Someone else can fill in that bit of info.
Old Jul 9, 2002 | 10:42 AM
v4lu3s's Avatar
v4lu3s
it wont be worth a lot, if the a/c is off all it does is spin the pulley since the compressor is already disengaged. plus if you cut that belt you lose the alternator...
Old Jul 9, 2002 | 11:41 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
How so? The A/C and ALT belts are independent.
Old Jul 9, 2002 | 11:42 AM
v4lu3s's Avatar
v4lu3s
you dont own an accord do you?
Old Jul 9, 2002 | 11:57 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
So the a/c condensor and alternator on an Accord are driven by the same belt? That's odd. Learn something new everyday.
Old Jul 9, 2002 | 12:07 PM
v4lu3s's Avatar
v4lu3s
heheh yeah
on accords and ludes the ps pump, alternator and compressor are all stacked...and the ps pump has its own belt while the alternator and a/c share one.
kind of a hassle to service the a/c compressor...more than ahassle actually, more like a pain in the ass.
Old Jul 10, 2002 | 07:39 AM
jdblack1's Avatar
jdblack1
As long as the A/C switch is off then it's not taking hp. But once the AC is on I can see it eating maybe 10hp or so. I know my Accord has no power with the AC on.
Old Jul 10, 2002 | 09:37 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It actually does take some engine power to spin the pulley, even if the a/c unit is off, but you probably wouldn't even feel the difference if you were to remove it.
Old Jul 10, 2002 | 07:07 PM
fastball's Avatar
fastball
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
On most 4-cylinder engines, you will loose somewhat noticeable power with the A/C on, since there is a lack of torque. With most V-6 and V-8's you won't notice anything. But if you need the power, just don't run the A/C at the time. Cutting the belt won't do much for you.
