Ground Control coilovers
Old Jun 25, 2003 | 10:31 PM
MY_RSX-S's Avatar
MY_RSX-S
Default Ground Control coilovers
My RSX-S came with ground control coilovers. The thing is the front ones I cant adjust. The spring seat won't turn. Its like stuck or something. So I just want to make sure ...that is it perfectly fine to unscrew the little bolt that keeps the spring seat together? I want to do that so i can adjust the springs and clean out the threaded sleave.
Any help or comments are appreciated. Thank you
Old Jun 26, 2003 | 08:59 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
if it is the allen bolt on the gold piece of the coil over then yes you have to unscrew it to adjust them. Also, if there is some road grime or crap on the red threads then take some carb cleaner or contact cleaner and spray them off. It works really well and helps so you can adjust them easier.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Jun 26, 2003 | 05:09 PM
MY_RSX-S's Avatar
MY_RSX-S
yeah I is the allen bolt, all of them i can't adjust except one...one i don't need to unscrew the allen bolt...so im assuming that was not tighten securely in the first place.
So i can unscrew the entire bolt off. Thanx for your help
Old Jun 26, 2003 | 05:33 PM
Import-Tooner
skoooooie!
You should just need to loosen the bolt. Don't take it all the way out. It might be kind of a pain to put it back in....
