My own passenger door problems..
Old Jun 19, 2003 | 11:30 AM
Daniel's Avatar
Daniel
Default My own passenger door problems..
..it seems that with my passenger door closed, neither I nor my passenger can roll that window up or down. The passenger also cannot unlock his door from his side. Only when the door is open is when all controls (both driver/passenger side) work for that door. Anyone had any experience with this?
Old Jun 19, 2003 | 12:13 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
Default Re: My own passenger door problems..
Are you pinching a wire or two when the door is closed?
I have no other idea.
Old Jun 19, 2003 | 12:15 PM
BonzoAPD's Avatar
BonzoAPD
maybe the window is slighly out of place and when it's in the closed position it can't move from it's position?
Old Jun 19, 2003 | 02:13 PM
Daniel's Avatar
Daniel
Remember, it's not only the window, it's the door lock too.
Old Jun 19, 2003 | 08:20 PM
90'RS's Avatar
90'RS
Does this still not work with the door closed when the window is partially down? Just to make sure there are no wires being pinch when the door is closed you should test at the switch when the door is closed with a voltmeter or test light. While you in there you should check the switch also to make sure this is working properly. If none of this works I'm all out of ideas.
Old Jun 20, 2003 | 04:27 AM
Daniel's Avatar
Daniel
I'll have to try that scenario!
