problem with A/F in LS/VTEC
Old Jun 12, 2003 | 01:01 PM
WojtekG's Avatar
WojtekG
Default problem with A/F in LS/VTEC
My LS/Vtec coversion runs so lean I'm afraid of driving it and can not find problem that causes such A/F ratio.
My setup is
B18B block
B16A head
P30 ECU
B16A Intake manifold
I wonder if someone could give me sum clues what can I do to increase A/F reachness. Can it be problem with ECU, so I hould use 1,8 VTEC ECU?
Old Jun 12, 2003 | 02:48 PM
Daniel's Avatar
Daniel
First of all, have you had your setup tuned, or are you running as you installed it?
Old Jun 12, 2003 | 10:13 PM
WojtekG's Avatar
WojtekG
I was not tuning up my setup yet, because I don't really know what exactly to do. I was expecting this LS/VTEC to work at reasonable A/F after just builiding it up. Right know it has 25% leaner fuel than the average level of 14.7:1.
Old Jun 12, 2003 | 10:20 PM
DB7 2.0's Avatar
DB7 2.0
Banned
bad O2 sensor? :dunno:
what are you using to check the air fuel ratio anyway?
Old Jun 14, 2003 | 05:03 AM
WojtekG's Avatar
WojtekG
I measure A/F ratio by means of some specialised equipment from Honda.
I checked O2 sensr and it was dead. I replaced it with new one and car runs better, but still header temperature is to high and spark plugs are too grey, so I think the A/F is still too lean. On Monday I will be able to measure A/F, but it seems that O2 sensor was not the major reason for he problem.
What Can I do?
