My DIY kit is halfway done
Old Jun 3, 2003 | 09:11 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
Default My DIY kit is halfway done
I posted in the Engine Tech forum, but for those of you Accord owners that don't browse there, I have a question about ground points:
https://www.honda-acura.net/forums/s...threadid=74009
Old Jun 3, 2003 | 09:36 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Just wondering, why would you ground the valve cover:dunno:
Old Jun 3, 2003 | 09:38 PM
mexican97LXcord's Avatar
mexican97LXcord
same here???
Old Jun 3, 2003 | 09:52 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
or "engine head"
I knew I should have never used the term "valve cover" since most of the time it's made of plastic. In my case it's metal, but I would be using one of the existing black bolts that go deep into the cylinder head along the cover in the pic I posted above.
Anyways, I just took a couple of pics of the wires if anyone's interested:
Old Jun 3, 2003 | 09:55 PM
mexican97LXcord
still wondering why bro?
Old Jun 3, 2003 | 09:56 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
lol you should get your car dyno first before doing this mod. I want to see 1hp increase hehehe
Old Jun 3, 2003 | 10:07 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
Most of these grounding kits that you purchase are attached to the "engine head" at one point in the daisy chain. I'm already running a wire from the battery to the engine block, so I think that may be enough.
I'l be lucky if I get 1hp. I'm doing this to make things run a little smoother, and better starts. Definitely NOT a "performance" mod.
Old Jun 4, 2003 | 12:50 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
I think getting an MSD or is it LSD :thinking: with an external COIL would given you a smoother and better starts or a battery upgrade.
Old Jun 4, 2003 | 02:55 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
MSD.
That MSD ignition will give you a better spark.
Upgrading your ground wires WILL NOT provide for a better spark.
Old Jun 5, 2003 | 05:53 AM
decibel_dj's Avatar
decibel_dj
well actually it is maybe not on a honda but other cars like the WRX. having a proper ground yeilds a couple of additional HP to teh wheels
