Grounding
I want to get the Hyperground Systems grounding kit:
http://www.sunautomobile.com
or the Arospeed kit (8 wires, but uses one grounding point)
I looked in the engine bay:
and, I could only find 3 stock grounding points:
battery -> engine bay front
battery -> tranny?
engine mount -> body
Are there more ground points that I've missed? So far I've heard of alternator, firewall, and intake/throttle body ground points. Do we only have 3 stock ground points?
I've heard of grounding the valve cover. What are these two threaded holes for? Would I connect a wire from either of these 2 points:
to the engine mount ground?:
what else have you all grounded/upgraded?
I'm thinking I'll:
1. Upgrade engine mount ground
2. Add valve cover ground
3. Upgrade battery -> engine bay front ground
How do I do the other points?
battery -> tranny?
I'm thinking I'll:
h: I just wanted to chime in and let u know that ur engine bay is freaking spotless! Looks good mang. How much is the Arospeed grounding kit? I have found the Hypergroud system for like a bill or a little more. Is the Arospeed the same?
I think it's $63? Someone on another board told me that.
BTW, would you believe that I've never washed the engine bay?
Only 5300 miles on the odo.
h: Mine is clean too, but urs is immaculate :thumbup:
Originally posted by VRGNCD5
If it's only approx $60, im getting the Arospeed kit, fawk Hyperground, it's the same shit. Coo, good looking out mang. Only 5300 huh? That explains it, i've got 110k
give me a full car detail job and I can pass this off as new
remember, that the Arospeed kit uses one grounding point, while the Hyperground kit lets you use multiple grounding points. But they could have at least included more wires for $100+
not me
But if that's a good ground, it's all good right? More grounds=more possible problem areas.
not me
you're probably right, but then again, the only wire I would be replacing would be the engine mount -> chassis. I would only be adding more wires, which should only help.
using what kit?
using what kit?
http://www.importtuner.com/tech/0212it_ppsuzuki/
