Installing AMP ?
Old May 19, 2003 | 11:07 PM
Turbonium's Avatar
Turbonium
Default Installing AMP ?
i want to install my amp but am wondering where i should pull the power wire through? anybody have any suggestion where on the firewall is a good spot that is possibly already open to be pulled through. i want to find a spot near the battery or anywhere near the passneger side.
Old May 20, 2003 | 12:37 AM
Spec R's Avatar
Spec R
Theres a grommet on the firewall down and to the left of your battery that works perfectly.
DB Squad
Integra Forum Moderator
Old May 20, 2003 | 07:54 AM
ssbluegsr's Avatar
ssbluegsr
on my teg the power wire was run to the drivers side and through a grommet there. And then it came under the dash.
Make sure you run the power wire and the RCA cables on opposite sides of the car so you don't get interferance.
Old May 20, 2003 | 09:06 AM
b00gers's Avatar
b00gers
i use the driver side grommet. remember to put the power wire INSIDE of the gromett. you dont want the sheetmetal cutting into the wire.
its best to take the whole gromett out, cut a hole in it, slide the wire in, replace gromett.
have fun. car audio rocks.
Old May 20, 2003 | 09:09 AM
Spec R's Avatar
Spec R
O yeah, on my car, i'm running 4 gauge wire to a 4-way, 8 gauge distribution block in the trunk. The cable is run through the passenger side. My RCA's are on the driver side.
DB Squad
