slight electrical problem
Old May 17, 2003 | 04:06 PM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
Default slight electrical problem
today i was lowering my gains on my amp when i forgot to ground the amp securely and something got shorted...all i know is on the dash the BRAKE light stays lit even when the e-brake is down and the abs light comes up after 5 minutes of driving...anyone have any clues to what might have gone wrong? solutions? is it the fuses? if so which one?
Old May 20, 2003 | 12:59 AM
Spec R's Avatar
Spec R
damn that sounds bad. i've been stupid a few times myself. i remember i was disconnecting the ground cable to the battery with a socket and a long extension, stupid me, i hit the positive post with the socket wrench by accident and there was a big spark
nothing bad happened though.
another time i was stupid was when i was reattaching the ground side of one of my amps, and my arm slipped while i was holding the ground cable, and it hit the postive side of the amp. another big spark
nothing bad happened here also...
As for your situation, i would definitely check all the fuses. The fuses are there for a reason, and those reasons are for what me and you have gone through (shorts). Check the box under your dash, as well as the one under the hood (sorry, i dont know where the abs and ebrake light fuses are, if they even exist)
Good luck :thumbup:
DB Squad
Integra Forum Moderator
Old May 20, 2003 | 06:21 AM
Anthony's Avatar
Anthony
thanx that's what i'm going to do today i'm probably going to replace all of my abs fuses and things
