Installed head unit, but no radio stations??
Old May 16, 2003 | 08:53 AM
AccordXL's Avatar
AccordXL
Default Installed head unit, but no radio stations??
This was my first time I installed a head unit on a car so I am not sure what happened. I bought the install kit and cd plays perfectly, but there is no radio signal at all. I did plug in that black wire that plugs with the factory black wire, which is think is for the radio. But I also noticed the Accord has no antenna that comes out? Am I missing anything?? The unit I got was a used Pioneer DEH-P2000 if that helps. Any help would be appreciated. Thanks guys.
Old May 16, 2003 | 09:03 AM
ur31337's Avatar
ur31337
Colby
The antenna should be in the back window, no worries there. Maybe it came loose from the back of the deck, that's happened to me before.
It couldn't hurt to check, especially if it was your first.
Old May 16, 2003 | 08:24 PM
SiClone's Avatar
SiClone
X-Moder8er
Yep, dbl check the antenna connection. If its secure, then the FM tuner is jacked up....
Old May 18, 2003 | 04:51 PM
AccordXL's Avatar
AccordXL
It is finally working. Thanks dudes.
Old May 18, 2003 | 09:54 PM
SiClone's Avatar
SiClone
X-Moder8er
Good for you!! :thumbup:
