cold air intake installation help
Old May 15, 2003 | 11:47 AM
integra91978's Avatar
integra91978
Default cold air intake installation help
can anyone help me out, does anybody know where to find the installation instruction for the cold air intake for integras on the net? thanks!
Old May 15, 2003 | 01:21 PM
crash's Avatar
crash
take off strut bar,take of stock intake,take of resonater(in bumper),instal CAI
the air box has screws holding it in,and the intake is clamped onto the throttle body,the vaper return line is that hose going from your valve cover to your intake,reatach that to your new one,do not buy an air breather,unless you are turbo.
that help any? have fun
Old May 15, 2003 | 01:33 PM
GSR9982's Avatar
GSR9982
jdmfan.com/technical/performance/aem_intake/
these are pretty good instructions, I didn't have a problem
Old May 15, 2003 | 03:53 PM
integra91978
hey, this website you gave me doesn't work, can you check to make sure it is correct. thanks a lot
Old May 16, 2003 | 06:08 AM
GSR9982's Avatar
GSR9982
yea it's right.. it must be down right now cuz I couldn't get it to come up either, I guess try in a couple days.
Old May 16, 2003 | 06:36 AM
ChopstiX's Avatar
ChopstiX
go to www.team-integra.net and register an account then go to the articles section. it has a full article with instructions and stuff on how to do everything!
Old May 16, 2003 | 08:11 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
You need to remove your front bumper...remove the strut bar (If any) remove the stock intake and resonator, remove the coolant resevoir and bracket, then you put the bottom part of the intake in first and then move the pipe around to get it to properly fit. Once you get everything stock of from the stock intake putting the CAI on is very, very easy!
Old May 16, 2003 | 08:52 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
You don't need to remove the front bumper. It can be done without having to do so.
Old May 16, 2003 | 09:02 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
You need to remove the front bumper to pull out the resonator...if you could get the resonator out without taking off the front bumper I would really like to know.
Old May 16, 2003 | 10:49 AM
ChopstiX's Avatar
ChopstiX
Yes you can do it without taking off the bumper. Thats what I did. Just go to team-integra.net and check out the article on the CAI install. its easy!
