CV Joint Breaking and Driveability?
Old Feb 2, 2011 | 01:39 PM
agentfouser's Avatar
agentfouser
Default CV Joint Breaking and Driveability?
Hi there, I've got a 95 Civic that has been making popping noises when I turn for quite a while now. I understand that is caused by the CV joints wearing out, but the car has now started to jerk suddenly to the left while driving. It occurs randomly, in short, sharp little jerks of the wheel. The car itself barely quivers while this happens. Is this evidence that the CV joint is so badly worn that collapse is immanent? I found this post which said that it might be the tie rod ends. Does anyone have any other advice about what it might be, and most importantly if I should try to drive home from Orange County to LA this evening? It's 50 miles on the freeway, probably considerably more on surface streets.
Old Feb 2, 2011 | 02:17 PM
94civicEX's Avatar
94civicEX
I got worms.
Sounds like your axle is literally on its last leg. I wouldn't risk driving it much longer.
You need to get it replaced ASAP.
99 Integra GSR
06 TSX
duck squad member #00003
Old Feb 12, 2011 | 03:22 PM
cruzalekz's Avatar
cruzalekz
definitely,first time i bought my suzuki esteem with a bad axle, the whole car , the whole car vibrates at 45 mph.
replaced it, problem was gone. car ran beutifully
Old Feb 20, 2011 | 05:39 PM
raconj's Avatar
raconj
same thing happened to me in my 94 civic. finally the day i bought the replacement axle i was pulling out of the parking lot and the joint finally made a loud pop and i wasnt going anywhere.
