Ingalls Install
Old May 14, 2003 | 06:41 PM
BlackGSR's Avatar
BlackGSR
Default Ingalls Install
Does anyone know how or where to grease the ingalls camber kit bushings? I don't really see where I can put any. Any help is appreciated. Thanks
Old May 19, 2003 | 08:21 AM
hondascc's Avatar
hondascc
nottajr
This should help.
Originally posted by agent87
These next few sections are the part I think many people forget to do! This is why some people complain about the polyurethane kits squeaking. It is also why simply spraying the outside will not work very well.
Push out the metal cylinder. They're not that hard to remove but to make life easier, i used a socket connected to an extension and hammered it out. (I forgot what size I used but that looks like a 10mm. Just use whatever looks like it will fit best.)
Lubricate! I used Energy Suspension lube and applied it with a cotton swab. The ES lube is actually kind of pricey and somewhat difficult to find. I bought my lube something like 2.5 years ago hoping to get it before I installed my own camber kit. Unfortunately, it didn't arrive in time. I instead used my friend's mountainbike suspension grease. (In my case I used Judy Butter - named after the Rock Shox Judy suspension fork.) You can get this stuff at a bike shop or you can use whatever water insoluble grease you want.
Slide the sleeve back in. Note that in this picture you can actually see the grooves in the bushing that are meant to hold the grease in. Some grease will push out the other end. If you feel especially unwasteful, you can wipe it up with the cotton swab and add it to the lube you'll be using on the next one.[/B]
Old May 19, 2003 | 04:23 PM
BlackGSR's Avatar
BlackGSR
Thanks man but I already put them in. I wonder if they put any lube in there when the make them? Oh well I'll just hope for no squeeks!
Old May 19, 2003 | 04:45 PM
Turbonium's Avatar
Turbonium
let me know how those camber are and if they're any good. arent ingalls sold on ebay as the majority of camber kits thats cheap.
Old May 19, 2003 | 04:48 PM
hondascc's Avatar
hondascc
nottajr
I am not sure whether they put any grease on them before they insert the pins or not. I actually put my kit on today and I didn't grease mine either. I was in a hurry so I said screw it. I figure if they squeak a lot I can put some grease around there later. Oh well we will see.
Old May 19, 2003 | 04:52 PM
hondascc's Avatar
hondascc
nottajr
Most of the kits I have seen are about the same. The only difference is that some only adjust +/- 1 degree and some adjust up to +/- 3 degrees. If you are going low you will definetly need the 3 degree one. One degree doesn't allow for much adjustment at all.
Old May 20, 2003 | 09:13 AM
b00gers's Avatar
b00gers
i made the mistake of not greasing my ingalls. i had about a year of embaressment and torture of having to hear the squeaks. then i ran into alvin's thread (agent87)...its a great DIY.
even with the ingalls kit installed and adjusted. you can still take the kit out and grease them without jeopardizing the adjustment by much.
to grease them after they are installed, remove wheel and the two nuts that are under the hood. slide the whole suspension unit out. remove the bolt and nut off each one, and grease. once again...good stuff.
Old May 20, 2003 | 08:07 PM
hondascc's Avatar
hondascc
nottajr
Yeah I think I am going to be taking mine out soon and greasing them. They are squeaking like crazy. If I have the radio up it doesn't bother me, but if I don't then it is bad. Plus I wonder what people are hearing outside of the car.
What kind of grease did you use?
Old May 21, 2003 | 09:07 AM
b00gers's Avatar
b00gers
people hear the exact same thing you hear from the inside. when going over speedbumps and up driveways. h:
i used a tube of white lithium grease. not the spray kind.
