Please help Choosing camber kit...
Old May 8, 2003 | 04:22 PM
Integra_95's Avatar
Integra_95
Default FRONT OR REAR Camber kit or BOTH?
I plan to get camber kit for my car. I know that i need one for the front. Is the rear really neccessary? my fronts got more neg. camber. Can I put washer on the rear? will the aligment shop be able to adjust my camber if I use the washer?
What brand of camber kit would you recommend buying?
I know it's a lot of question. I am new at lowering car. any help and/or advice will be greatly appreciate
Old May 8, 2003 | 06:40 PM
b00gers's Avatar
b00gers
tell the alignment shop to put in the washers for you. on the integras, you just need 2 washers on each side. of course it depends on the thickness of them. the alignment shop will "adjust" the rear by adding or subtracting washers.
i like and have ingalls in the front. i havent really heard bad things about them. just dont forget to lube them, and learn where to put the lube. theres a good DIY in the DIY forum written by agent87.
Old May 9, 2003 | 06:22 AM
Integra_95's Avatar
Integra_95
the shop prolly will charge extra for adding and subtracting washers since they have to take it out.
Can you adjust your camber at home for the rear by subtracting and adding washers?
Old May 9, 2003 | 07:54 AM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
you can do the rear yourself, you just have to add and subtract the washers. use a level to figure out when it is straight. you will still have to get an alignment to fix the toe, but you won't have to pay extra for the camber. JDMfan has a good article that they do the washers on for a civic, but it works on the tegs as well cause i did it.
Old May 9, 2003 | 01:05 PM
Turbonium's Avatar
Turbonium
how much would this cost for them to allign it as well as install cambers? just a rough estimate/
Old May 11, 2003 | 08:58 PM
Integra_95's Avatar
Integra_95
Default Please help Choosing camber kit...
I plan to get this camber kit off eBay. It's cheap. Can you please check it out to see if this is ok for my integra 95? I have sport H&R. I need camber kit badly. Thanks in advance.
DAD Front & Rear Camber kit 4 90-00 Integra
Old May 11, 2003 | 09:00 PM
Integra_95's Avatar
Integra_95
my local shop charges 60 to install each wheel. and alignment is 40. I prefer to install the kit myself and have them align it. Installation is easy.
Old May 16, 2003 | 11:11 AM
agent87's Avatar
agent87
Need zzzzz's
Default Re: Please help Choosing camber kit...
I know the auction already ended but to answer your question, that kit should be fine. HTH.
