2 amps with one 1 farad cap.
Old May 10, 2003 | 10:08 PM
Wharbone's Avatar
Wharbone
Default 2 amps with one 1 farad cap.
Can you hook up 2 amps to one capacitor?
Old May 10, 2003 | 10:13 PM
Matt86's Avatar
Matt86
vtec ownz j00
I'm not positive about this but i think it may be possible. Why do you need to do this?
Old May 11, 2003 | 04:26 AM
Randy12vp's Avatar
Randy12vp
Yes you can.
Old May 14, 2003 | 08:50 PM
acuradriva's Avatar
acuradriva
but the closer you get the cap to the sub amp the better it will be. if you even notice a difference.
Old May 15, 2003 | 04:12 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
I never understood the fascination with caps
If you really do need the use for one.. then the real solution is a higher output alt 1st and then a good cold cranking ampere battery.
And perhaps upgrading the the stock grounding system to 2 or 0 gauge.
Old May 15, 2003 | 06:42 AM
SiClone's Avatar
SiClone
X-Moder8er
Well, the fascination is this:
* 1 farad cap (helps a little with light dimming) = $60-70 (if you pay anymore, I'll send you some KY jelly )
* deep cycle battery (for extended playing with engine off) = $120-150
* new or rewound alternator (best results) = a lot more de to labor because the alternators on Civic's and Integra's are hard to get to
Old May 15, 2003 | 07:53 AM
moofoo's Avatar
moofoo
aaaah I see.. just what I thought :fawk:
You forgot one more thing the "cool" factor
"y0000000000000 I got this phat @ss 1 farad cap
and my bass is poundin!!!! (when in reality he's only running 160watt RF punch160a2 to a 12 punch sub the kid lives about 2 blocks away and all I ever hear is his mouth running and impressionable younger kids looking totally brainwashed) "
ugh sad sad sad...
Old May 19, 2003 | 05:02 AM
myles's Avatar
myles
they are a quick and easy fix to some major dimming problems...if you really had dimming problems i would say wire a new battery into the car, but for like $30 at walmart it's worth it for the extra power your amp gets. Atleast that's my opinion.
Old May 20, 2003 | 09:35 AM
b00gers's Avatar
b00gers
i dont think there is anything wrong with using caps. you can show me how there are studies to how they dont do shit. i just know for a fact that for under $100, i got rid of the dimming of my dash and headlights.
and ontopic...which 2 amps do you want to hook the cap up to. if you need a cap, you need the cap hooked up to the amp that is powering the bass. everytime your lights dim, its when the sub amp is grabbing a surge of power from the car electrical system, therefore not leaving much for the rest of the car.
a cap will not solve the problem with dimming if you have a 150 or 200 amp amp on your honda. h:
Old May 30, 2003 | 09:52 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
HMMMMMM, someone that knows what's going on in the car stereo world - I think caps are BS because they only are a patch for too thin power wire. They DO NOT at all help with alternator output voltage stability (aka lights dimming). All a cap does is "stiffen" the powersupply to the amp (which has smaller caps built in to it already) kind of acting like a small battery, but it won't "boost" your charging system voltage - in fact everytime the cap gets discharged it has to get recharged, which requires current on top of what the amp is drawing. The only way to fix light dimming issues are to upgrade your wiring and to install a higher output alternator - no ifs ands or buts about it. I have two rockford amps in my car that will draw peaks of 120 amps when played loud enough, but I don't have a cap and I don't need one b/c my wiring is beefy enough and I have no light dimming issues b/c I run a modified accord alternator that puts out 150 amps at 1500 rpm - enough to cover the system and the extra load from the rest of the car. The one and only thing that IMO justifies a cap is that it can reduce noise a bit from the charging system from the car - that's just about it! Spend the extra 100 bucks on thick wire!
