Compression in LS/VTEC: 11.6:1?
Old May 9, 2003 | 03:40 PM
WojtekG's Avatar
WojtekG
Default Compression in LS/VTEC: 11.6:1?
I just calculated compression ratio in LS/VTEC I'm bulding. I used c-speedracing on-line calculatior. The result was 11.6:1, when I used B16A with B18A and pistons from B16A USDM.
My question is: Is this compression too high for this engine to make reliable or I don't have to worry about it t all? Are there any necessary additional upgrades to the hybrid engine I shoud make to be secured with such compression?
Old May 14, 2003 | 12:26 PM
uoboarder's Avatar
uoboarder
Got Boost? I used to
Default Re: Compression in LS/VTEC: 11.6:1?
I don't think 11.4 is too high at all. I just met a guy 2 days back that has an LS/VTEC with CTR pistons with a GSR head that has been milled .25 thousanths. He's running 12.4:1 C/R. He runs 92 octane and doesn't have any problems.
Of course if you can go with somewhere around high 11s or low 12s C/R then do it. All you have to do is back the ignition out a little if you notice that you're pinging. However, I still don't think you'll have a problem.
