Check Engine Light
Old May 6, 2003 | 11:55 PM
Turbonium's Avatar
Turbonium
Default Check Engine Light
i know check engine lights are a common problem but i have it now.
i just installed a new racing cat and CAI on my 02'gsr and the check engine light has been coming on every once in a while. my friend told me it might be the CAI if theres a problem with too much air going in. any advice and help, cuz so far i just disconnect the battery and it goes away for a while, and i dont want to keep doing this over and over.
Old May 7, 2003 | 08:07 AM
JimBlake's Avatar
JimBlake
Don't just keep clearing it... Read the code so you can start guessing what the real problem is.
Old May 7, 2003 | 08:11 AM
reno96teg's Avatar
02 gs-r? :eh: there's no such thing.
like jim said, definitely don't keep clearing it. obviously something is up if you're getting the CEL. check the codes and see what it is. here's how: http://www.bseries.net/html/garage/engcode.php
Old May 7, 2003 | 08:29 AM
JimBlake's Avatar
JimBlake
Originally posted by reno96teg
02 gs-r? :eh: there's no such thing...
Oh yeah, I didn't even notice that.
AutoZoned or someplace like that will read the code for you for free. Just get them to tell you the actual code number, not just their guess for what's wrong. Then come back & tell us the number.
Old May 7, 2003 | 09:58 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
I doubt it is your CAI that is doing this...if anything there may be something wrong with the O2 sensor on the CAT you installed. Either it is not on right, broken, or not installed at all.
Just a thought.
Old May 7, 2003 | 10:16 AM
Turbonium's Avatar
Turbonium
yeh sorry about that 02' post, weird, its a 2000 and i guess i put it backwards. my friend that drives an is3000 swears its my CAI but i also think its my cat, when it was installed. so i guess ill call around and see who can check the code for me.
but also, how would i go about fixing this and how much if i bring it into a shop?, do i need an o2 similator?
Old May 7, 2003 | 12:35 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Here's my guess.
The two O^2 sensors [before & after cat] are either confused, or one isn't working properly. Though it seems too soon for an oxygen sensor to wear out.. :dunno:
:thinking: Has your MPG plummeted?
Is it possible for the two set of wires to be plugged in wrong-way round (the after cat sensor accidentally plugged into the the pre-cat sensor's harness or vice versa)?
The code number will help for sure.
Dave
Old May 7, 2003 | 01:01 PM
bengeeee's Avatar
bengeeee
You can check the code number yourself. Its easy with a paper clip and a chart. Lemme search more for that method. I cant remember the specifics. If someone finds it before me or remembers how to do it please post.
Ben
Old May 7, 2003 | 01:29 PM
bengeeee's Avatar
bengeeee
u sure you have a gsr?
Old May 7, 2003 | 02:44 PM
XSrcing's Avatar
XSrcing
i bet its a code for the second O2 sensor cycling too fast. and i bet the light comes on after you have been on the highway for a little bit. if that is the case, the only way to fix it is to install a cat.
