1991 integra Ls
Old Nov 11, 2010 | 01:53 PM
docglen909's Avatar
docglen909
Default 1991 integra Ls
Need help with front wheel bearing, What is the best way to change the bearings on my car? I have 365000 km on it and the bearings just started to make a grinding sound, The car has been in the famaliy since new
Old Nov 13, 2010 | 10:17 AM
cruzalekz's Avatar
cruzalekz
theres a kit they sell on ebay for 150 bucks i believe where you dont have to remove the whole knuckle.
or you could take the knuckle apart and bring it to a shop and have them press it out and put in the new bearing.
do the math which ever saves you time and money.
Old Nov 23, 2010 | 01:55 PM
docglen909's Avatar
docglen909
Default wheel bearing
changed the wheel bearings and all is good payed 70 each and did the job in 2 hours but now have a problem with the head lights, when its cold out the light take time to come on, what could the be?
Old Jan 15, 2011 | 03:45 PM
cruzalekz's Avatar
cruzalekz
bad ground for headlights, corroded connector (moisture at connectors) , or its just the bulb f#ckin up.
