cold air question
Old Apr 26, 2003 | 07:15 PM
Air Talaria's Avatar
Air Talaria
Default cold air question
hey guys, i am looking at getting a cold air intake for my rsx type s. i was just wondering which one is the best to get for better perfromance.
thanks
Old Apr 26, 2003 | 07:18 PM
RSXoholic's Avatar
RSXoholic
the anti-rice
theyre all the same. the only difference is the time for install. the aem will take longer because you have to relocate the washer fluid bottle.
Old Apr 26, 2003 | 11:30 PM
94civicEX's Avatar
94civicEX
I got worms.
I personally like the Injen short ram.
99 Integra GSR
06 TSX
duck squad member #00003
Old Apr 27, 2003 | 02:23 AM
Randy12vp's Avatar
Randy12vp
Injen cold air.
Old Apr 27, 2003 | 01:53 PM
K i o n's Avatar
K i o n
TrackDemon
Originally posted by Randy12vp
Injen cold air.
yep, ive heard the DC bottle leaks as well
Old Apr 27, 2003 | 07:06 PM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
Agreed...
Old Apr 27, 2003 | 08:01 PM
NSBTypeS's Avatar
NSBTypeS
MMM MMM Bitch
Go with AEM, just a biased thing towards them, all teh other intake manufacturers have succeeded in copying AEM's designs. So what if you have to relocate the washer bottle, the DC sports one still requires you to run the wires accross the bumper to the other side, and thats the pain, not putting the bottle to the other side. You still haev to rip off your bumper and do all the dirty business, get the AEM, you wont be dissapointed.
Old Apr 28, 2003 | 06:27 PM
K20AMUGENPOWER's Avatar
K20AMUGENPOWER
no question AEM
Old Apr 30, 2003 | 07:06 PM
typesinside's Avatar
typesinside
The Injen CAI is the best dyno tested it beats the AEM CAI which delivers 20+hp and add 5 lbs of torque so i would do Injen
Old May 3, 2003 | 11:12 AM
Pooya's Avatar
Pooya
Ok....here is the scoop on most intakes for the RSX. Import Tuner's may 2003 came out with a section on intake system for the RSX and here is what they found.
First number is HP second is LB-FT and last is estimated price
1. Injen 9.2, 2.9 $320
2. AEM Cold Air 20.7, 5.3 $392.81
3. AEM Short Ram 5.4, 4.9 $239.50
4. DC Sports Cold Air 19.7, 5.7 $N/A
5. Jackson Racing 7.8, 4.2 $N/A
6. K&N Typhoon 7.4, 3.1 $285.37
7. DC Sports Direct Air Charger 9.2, 2.4 $179.95
Now, these prices are WAY overpriced I think. The AEM Cold -Air is like 250 I think....the prices are off but the specs give you some idea of what the preformances are of these Intakes.
In conclusion, the AEM cold-air gives you more HP and the DC cold-air is 1 horsepower less...however the DC cold-air gives you .4 LB-FT more then the AEM. Keep in mind they even reported the same constant temperature for all intakes. For example, when they tested these intakes, the outside temperature (which plays a role) was 87 degrees and also the under the hood temp was about the same.
One more thing....the AEM intakes temp. was the lowest at 96.5 degrees while the DC was close to 97 degrees. The Injen was 113.5 degrees.
So all in all, I think I personally would go with the DC cold-air because its about the same as the AEM in power and in temperature but yet I believe its cheaper...not sure about the price difference but I think its cheaper. I had an AEM on my 96 Prelude (vtec) and I loved it but I think I'll personally go with the DC this time. The difficulty rating of the DC was less because DC provides a new bottle that clears the intake rather then the AEM which you have to relocate the winshield washer bottle to the opposite side of the compartment.
