Gsr rear brake problems.
Old Jul 26, 2010 | 06:54 PM
dkgsr's Avatar
dkgsr
Default Gsr rear brake problems.
i got an 99 integra gsr and i changed my rear brake pads like a year ago, but the driver side rear works and the passenger rear doesn't work when i pull the e-brake . when i pull the e-brake it goes all the way up and only the driver side rear brake works. When i brake all four of them work but the passenger side is a little slow.
Old Jul 26, 2010 | 07:12 PM
dkgsr's Avatar
dkgsr
com on guys. help me out.
Old Jul 30, 2010 | 07:13 AM
Tobra's Avatar
Tobra
maybe stuck caliper, maybe need to adjust hand brake cable.
Old Aug 4, 2010 | 07:32 AM
dkgsr's Avatar
dkgsr
oh i tried that already.
didn't work. the driver side cable is more tense than the passenger side one.
the passenger side cable pulls all the way up making the bracket look like this "/". if you get the picture.
Old Aug 4, 2010 | 11:10 PM
ReaperOne's Avatar
ReaperOne
Check to make sure your caliper compresses and decompresses, it may be stuck in the open position. . . you may need a new caliper, same think happened to me on my 96 Ls sedan. . .
Old Aug 14, 2010 | 03:52 PM
cruzalekz's Avatar
cruzalekz
caliper stuck, unfreeze it with a c clamp. then do a manual bleed on the fluid
Old Aug 15, 2010 | 11:45 PM
Spec R's Avatar
Spec R
u cant use a c-clamp on the rear, its the turning kind with the X.
maybe you didnt get the brake pad nimple in the groove of the "X"?
DB Squad
Integra Forum Moderator
Old Aug 17, 2010 | 12:02 PM
gsr converters's Avatar
gsr converters
does it only not work with the Ebrake? normal braking good? might need to re-adjust the cable, or need new cables. sometimes they get worn and break.
Old Aug 21, 2010 | 10:03 AM
cruzalekz's Avatar
cruzalekz
yes you can use a c clamp in this kind of situation. i forgot you need an ajjustable plier to turn the piston while pressing with the c clamp... works coz inve done it a couple of times at the shop. new trick eyy
