Obd2 Injectors
Old Jul 12, 2010 | 08:58 AM
micha177's Avatar
micha177
Default Obd2 Injectors
Just had a quick question... Im putting an obd2 gsr engine into an obd1 gsr, and im wondering if i have to wire up a resistor box for the injectors to work.
Old Jul 12, 2010 | 07:07 PM
Spec R's Avatar
Spec R
which ECU are u going to use? what engine harness is being used?
match everything according to which OBD ecu you're using
DB Squad
Integra Forum Moderator
Old Jul 31, 2010 | 11:23 AM
micha177's Avatar
micha177
so if im using an obd1 ecu, then i should use the obd 1 engine harness and i shouldnt need a resistor box? should i just splice in the newer injector clips?
Old Aug 14, 2010 | 03:59 PM
cruzalekz's Avatar
cruzalekz
nope, im a smog tech and if you are using an obd2 engine, you should use an obd2 ecu and wirings as well so you wont have a problem with pcm test while getting a smog
